can a turbo be heat wrapped?
Old 22-11-2009, 05:52 PM
my-first-rst
tokey smurbo
my-first-rst's Avatar
Default can a turbo be heat wrapped?
quite a simple question really, can a turbo be heat wrapped and will it do it any damage etc if it is?
just thinking of ways to keep under bonnet temps down?
cheers
steve
Old 22-11-2009, 05:57 PM
Yes and no in that order, you can buy specific turbo jackets for this very purpose.
Old 22-11-2009, 05:58 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
cheers
steve
I used a Turbo jacket on a Topspeed run & it cooked the Turbo, I also know that Neil (Carwise) had the exact same problem on another Topspeed run using a jacket so i dont use one.
Old 22-11-2009, 10:13 PM
my-first-rst
tokey smurbo
but i wont be doin top speed runs, mayb the odd 1/4mile but thats it? hmmmm
when you say it cooked the turbo what happened to it?
steve
Old 22-11-2009, 10:19 PM
phil_rs
yam yammer
phil_rs's Avatar
I also know someone who cooked a new turbo when he heat wrapped it so personally wouldn't. I would do the downpipe and manifold, also we have found wrapping the charge carrier pipe on an rst reduces charge temps
Old 22-11-2009, 10:46 PM
Rick Astley
Never gonna give you up!
Rick Astley's Avatar
steve
In that case, why is a reduction of engine bay temperature required? Surely you have sufficient cooling in there as it is. Maybe you are just looking into something that is not neccessary?
Old 23-11-2009, 11:37 AM
my-first-rst
tokey smurbo
well its a zetec turbo in a mk3 fiesta, its a tight squeeze in there to say the least and my intercooler covers my whole radiator. and i dont want the turbo building up under bonnet temperatures as i dont want the engine running too hot
cheers
Old 23-11-2009, 12:04 PM
More vents in the bonnet would help.
If you have a mental car like the worlds fastest OAP, then I wouldn't use one either, but most are not like that, Rod does bloody well imo for his age, good to see it, would like one day a passenger ride but need to buy some more pants first!!
JK12
33
26-04-2021 12:09 PM
kevin36
02-09-2015 06:24 PM
jdsjojo
30-08-2015 07:48 PM
Ford Focus ST Parts for Sale
28-08-2015 01:32 PM
Quick Reply: can a turbo be heat wrapped?
