removing the imput shaft
Hey all im doing a 24v boa conversion on my 2.0 gls sierra, question is how do you remove the imput shaft from a v6 4x4 mt75 and put it into my 2wd 2 litre box?
The 4x4 conversion is most covered for info, where as the 2wd isnt. Ill also add that ive split the gearbox and put the v6 front casing on my 2wd box already just remembered that the shaft is about 30mm too short
cheers all
tom
cheers all
tom
07-10-2015 12:56 PM
