heated rear window ariel amplifier mk4 xr3i
ever since ive had the car the heated rear window and fm band on the radio have not worked at all, i have today taken the panels off the inside of the bootlid and had my electrical tester handy and dont seem to be getting any power from either of the wires entering each end of the amplifier unit. some one had disconected the rear window on the driverside connection (the window is fine because i have tested the resistance and fm still does not work nor the HRW)
which is supposed to be the positive wire enteriing the amp and which is the positive leaving the amp? thanks.. maybe broken wire sumwhere but cant find any, tried new relay and fuse is fine...switch iluminates etc.
the rear wiper and washer works fine.
theres a beesting ariel fitted at somepoint and im not sure which ariel is being used currently would this make any difference to the hrw?
thanks for any help
thanks for any help
The reception is normally very good through the HRW, if the amp is working ok.
Which aerial is the aerial lead connected to, this will determine where the stereo is searching for a signal.
It might be easier to find the earth at the aerial, as there are only two wires the other must therefore be the live, disconnect the wires and see if one is going down to earth.
What colour are the two wires you have ?, be aware that VERY often the wires break inside the insulation where they go through the grommet/tube into the body from the tailgate, of course being broken inside the insulation you can't see it, but probing along the wire till you find a hot(live) spot will show you where the break is, trace both the amp wire colours to the rear of the stereo, this should also help in identifying the live.
wires are black and other is red and white assuming obviously black is earth but something does quite add up with the tester must be a broken wire do you know where they run once inside the roof through that grommet from the bootlid?
also where do the speaker wires run for rear? its fed down into the inner wing sumhow and dont know where it goes then im thinking thats damaged aswel
Black is LIVE, never ever earth, not on a european ford anyway, is on certain others though!!
On european fords BLACK is a SWITCHED live, ie after the switch, presumably this would be from your stereo, the other may also be a live if earthed through the body of the amp, presumably the hrw wire goes through the unit also ?
yes there is two wires going into the unit...one i assume is earthed to the boot lid and another (red and white) ...and on the other side of the amp is the two black wires connecting to the heated rear window i cant detect voltage anywhere with hrw switched on and with fm selected to search on the radio
with engine running (incase it made a diff to hrw operation)
after a lot of faffing around in the rain it turned out to be the HRW switch playing up and breaking the circuit for both the amp and the HRW so now i have Fm and hrw working
only thing now is the drivers rear speaker is dead...wiring it fine all the way from the speaker to the ford equalizer/amp unit ....must be internal fault with the unit or sumwhere between the unit and the radio ??? hmmm
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
09-10-2015 07:38 PM
borboyous
22-08-2015 11:17 AM
track.focus'd
12-08-2015 05:53 PM
