cooling fan wont work.make of vehiclke ford fiesta mark 4 1992 model
cooling fan wont work. checked fan with alternate power source works ok. checked fuse ok. put new thermostat on thats ok but still wont work. can anyone help please.
Have you checked the tempreture switch in the radiator, there should be two wires going to it. Take the wires off and with a piece of wire bridge the two wires if the fan runs then its the radiator switch, Remember you will need your ignition on. Hope this helps and good luck
re cooling fan
Thanks for the input, tried the bridge. The switch has gone caput replacing tomorow nice one.
vdun01
Ford Fiesta
05-10-2017 08:14 AM
