| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
ZVH sold =(
#2 |
check the servo pipe, start the car up and listen for any sucking / hissing noises.
put your foot on and off the brakes you can get a m8 to do this while you listen under the bonet to see if you get any funny noises. it deffo sounds like a servo problem. you could always try removing the servo pipe and blocking it up to see if that helps althought i wouldnt advise driving with the servo pipe removed unless you got strong legs!!. check all the boost hoses / clamps, give them a squeeze see if any of them are very soft, or have splits / cracks. failing that take it to a garage. Last edited by RSargie; 19-11-2009 at 10:18 PM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can a ISCV cause idle revs as high a 2500 rpm?? | JanDK | Ford Sierra / Sapphire / RS500 Cosworth | 27 | 21-04-2010 03:54 PM |
| No boost and wont rev past 3K rpm? Limp Mode? | Mitch01roo | Technical help Q & A | 11 | 10-12-2009 08:06 PM |
| Does the coilpack conv handle high boost and rpm? | Lars_Ferm | Ford Escort RS Cosworth | 12 | 05-10-2009 09:31 PM |
| escos t34 no power/rev limit @ 4k rpm | dj1 | Technical help Q & A | 4 | 15-10-2008 07:37 PM |
| boost cut out at high rpm ?? | 220TC | General Car Related Discussion. | 14 | 27-10-2004 11:59 PM |
