Ford Explorer 4.0 1997 Help
Old 18-11-2009, 10:25 AM
tocca
tocca's Avatar
Default Ford Explorer 4.0 1997 Help
Hey guys, the old mans got a bit of trouble with the Explorer, when he goes to brake when its idling in traffic, or to put it in gear the engine starts to missfire and cut out. Taken the vacuum pipe off and when brakes pressed without it connected all is fine. So im assuming it could be down to a faulty sensor or servo? Swapped the MAF over and that hasnt made a difference. Any ideas? Cheers
Old 18-11-2009, 05:12 PM
I think you are on the right track, as in something is causing it to run lean, servo one way valve would be my guess.
Billy_RS
15
05-09-2015 12:04 PM
RockinRein
19-08-2015 07:08 PM
c14rks
11-08-2015 05:17 PM
Quick Reply: Ford Explorer 4.0 1997 Help
