Second Hand Diesel Pump
Hi, My ford focus w reg tddi fuel pump is nackered.
I can purchase a second hand 1 for around £200
I have been told if i fit a second hand 1 and even if i get it reprogrammed at ford the pump will not work, ???? is this true?
furthermore i was told if i purchased a second hand pump i would also need to purchase the igniton and door locks from this car so it will work in my car.
Also some garages are looking for around £300 mark to fit the pump and a new timing belt.
How easy or hard is it to fit a fuel pump ? as since i dont start my new job in a 2 months time and money is to tight to mention ( simply red), i will give it a go myself.
All replys will be greatly appreciated
Thanks
cellitstore
Thanks
cellitstore
At the very least the pump must be coded at the Ford dealer because a part of the anti-theft system is incorporated in the pump. Check with your local dealer if they can code it and if it's possible to code second hand pumps.
i fitted a 2nd hand pump to a diesel focus, coded for £50 and worked great, search my threads as ive asked it all before, theres differences with tdi's and tddi's if i remember but i cant remember which one i had.
wheelwizardrefurbs
23-09-2015 09:21 PM
