4wd fuel pump relay wiring fault!!!!
Old 16-11-2009, 01:13 PM
FlashRS
FlashRS's Avatar
Default 4wd fuel pump relay wiring fault!!!!
Hi, I have just fitted a 4wd engine loom into my 2wd 3 door, as I have just fitted a 4wd motor, I am not getting the earth signal to operate the fuel pump relay. When I turn the ignition on, the relay does nothing!
The wiring from pin 28 to the relay checks out ok.
When I give the relay an earth, the relay operates and the motor will run.
Any ideas??
mickparky81
Ford Focus ST
30-08-2015 06:58 PM
YODI
30-08-2015 01:12 PM
ekjim
27-08-2015 05:20 PM
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: 4wd fuel pump relay wiring fault!!!!
