2 questions
Old 15-11-2009, 09:49 PM
griffo69
griffo69's Avatar
Default 2 questions
Evening all as title I have some questions about my rst
1. All lights work on car exept the indicators/hazards. I found a loose blue fuse in fuse box is this it and where does it go for indicators
And
2. By the starter motor the blue wires I have broke the join in the clip. One end is on the alternator cable which I have but is the other wire joined to starter, I would look but I'm not around car now
Thanks
Old 16-11-2009, 12:53 AM
griffo69
griffo69's Avatar
also when trying to start it, it just clicks and i have dash lights working as are front and rear lights.
Old 17-11-2009, 10:53 PM
forevaford
forevaford's Avatar
flat battery?? blue wire goes to battery light on the dash
Old 18-11-2009, 05:25 PM
The blue wire as said is connected to the "IND" terminal on the alternator and goes to the warning bulb(charge light).
I would obviously fix the loose fuse, but 1 fuse alone won't cause this problem, as the hazzards are on a permanently live circuit(so they work with engine off/key out), the indicators work on position 2.
Make sure the battery is fully charged, and then look at the front indicators bulb holders to see what colour wire is each side, then find these colours at the stalk(indicator switch) put on indicator and see if this side shows live when put on to start with.
The click you hear could be as said simply a flat battery or a stuck/duff solenoid, give the solenoid a good whack first to see if it makes things better.
M7 COS
Wheels and Tyres
01-10-2015 04:46 PM
locum8
01-10-2015 01:50 PM
Iain Mac
30-09-2015 09:39 PM
stevecfrst1
30-09-2015 05:18 AM
Quick Reply: 2 questions
