Stainless Steel Exhaust Assembly Advice
Old 12-11-2009, 11:36 AM
jedi0_3
jedi0_3's Avatar
Talking Stainless Steel Exhaust Assembly Advice
Afternoon all.
When assembling a Stainless Exhaust should I be using assembly paste to minimise blowing joints or should it be o.k. with dry joints?
Got a Scorpion stainless jobbie to fit to my XR3i and just wanted to check, thanks!
Old 14-11-2009, 03:25 PM
I always give the joints a swimming lesson in Coppaslip or similar, helps if you ever need to take off again, but joints if blowing slightly will coke up sometimes anyway.
I don't use any on the manifold/exhaust on my 2wd, just where pipe fits inside another in system.
jessie_rs
62
06-08-2019 09:27 PM
charlierothwell
Ford KA
05-11-2015 06:56 PM
BRAMMER
15
14-09-2015 08:52 PM
little bram
10-09-2015 10:45 PM
Adam Graham
06-09-2015 06:04 AM
Quick Reply: Stainless Steel Exhaust Assembly Advice
