Ignition Problems
Ignition Problems
right car was running fine about 2 hours until i accidentally touched the starter motor with a scredriver which caused a big spark. now i can when the car is running i can take the keys out the ignition and the car will still run. Weird thing is when i touch the brakes or turn the lights then off the car will die. What is causing this????/
Russ Payne
25-09-2015 08:29 PM
