Is there a connector to lubricate the prop shaft somehow?
I seem to remember that there should be a way to lubricate the prop shaft? Is there connector for a grease gun somewhere or do you I need to buy a connector and screw it into place?
Doing some work on the exhaust and had the heat sheild down so thought I would look into this.
Could also use some tips on what grease to use.
cossie fan (unluckerly)
each prop sharft uj has a small grub screw in it u will need too remove the grub screw bin it and fit grease nipples then u can grease it any good work shop grease gun grease will do mate
07-10-2015 12:56 PM
muz
30-09-2015 08:29 AM
