rs turbo no spark
rs turbo no spark
hi peep got a problem wid a 2.0 zvh earlier was drivein it givein it a bit then the power died of and now wont start cant seem to get spark changed the coil for good one and put a live from the battery still no spark any help welcome thanks
yam yammer
They kinda have a primative knock sensor on some S2's but this wouldn't cause it not to spark. The distributers are quite common to fail, does it have a cable tie around the black plug on it? Failing that it has been known for the green wire from the coil to break and/or earth out which would stop it sparking
Yes you can, BUT not permanently, as ignition curve will be wrong, but it will certainly be ok to see if that is the problem, and use gently till get correct one, probably has more retard once on boost than a std one.
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
