what is a safe boost on 2.0 zvh
as above what is safe to run in psi or bar.
p.s. as far as im aware its all standard conversion parts on the car at the mo
got a 2.0l zvh mainley standard bottom end with skimmed pistons and im runnin around 10-12 psi been told that with skimmed pistons no more than a bar of boost (14.7psi) if the pistons are standard probley arond 3-4 psi
hope that helps which makes 175bhp 205fpt
3-4 psi on a 2.0l zvh? standard frst run 7-8 psi... n 16 psi wit a stage 2 chip n beige injectors n obviously -31 actuator n ugraded fuel pump as mine is set so surely u could get more than 3-4 psi outta standard 2.0 zvh?
YES I KNOW I CANT SPELL
one engine mite make 200bhp at 15 psi yet one with a ported head mite make 200bhp at 12psi
Bodger of Blackburn
i'm running/was running 11psi and just shy of 200bhp on a 1.8 on skimmed early pistons, as they have thicker crowns than later ones or the 2.0 pistons.
15psi is said to be fine, but i know a guy running 20psi on a 1.8zvh silvertop with skimmed pistons and he puts his on track and is still on the first engine, kicking out 318bhp with NOS on top of that.
that is quite a low reading of power for the boost on a zvh.
Bodger of Blackburn
very general i know, but a frst LUK clutch can't hold the power/torque back on 10.5psi of boost and they're usually good to 180-190bhp and what ever torque may be applied to that.
the general info i've been told about on zvh's is that 11 psi or there abouts should give 200bhp(ish) on a CR of around 8:1
etg ? sorry im new to all this
also i have one of these compression testers ( pic below) what would be a good number for a 2.0 zvh p.s this is urgent please help
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
