fuel guage not working please help
i own a s2 Dreg escort rst and my fuel guage is not working it just sits at 3/4 full. can any one tell me if this is a easy to find fault what should i be looking at and how to fix
could be either a wiring fault, guage or sender duff or stuck, look on the side if the tank and you will see the wires for the fuel sender, disconnect and re check the guage, should show empty, then short them out and it should show full, if it does its the sender unit that faulty if not its either wiring or the guage itself, then easiest thing is to try another set of clocks first
Almost certain to be sender unit I would say, I would think it's jammed at the 3/4 mark, the fact the gauge shows a reading shows the circuit to be complete that is presuming the gauge needle hasn't simply jammed guessed you have tried tapping the gauge?
Martin
Martin
I don't know about your model, but on early sierra's the actual gauges, temp and fuel had a mechanical adjustment on them, where you could physically adjust the needles position.
now it seems to work on the top half of the gauge i.e half tank is empty but its seems to get a reading so i will see about adjusting the needle
steerfromdarear
28
29-01-2016 06:14 PM
Zoggon
10-08-2015 10:39 AM
CabrioTurbo
01-08-2015 11:04 AM
