saph cosworth front drive shafts
hi all. quick question, are the front drive shafts on a saph cosworth 4x4 shorter then the front drive shafts on an xr4x4? i ask this as i im building the front end up on my saph cossy and ive had to buy a n/s/f drive shaft from a xr4x4 as the original 1 was u/s and it doesn't fit as its just a bit too long.
cheers
cheers
cheers
Shit, seriously??? Have just bought some xr4x4 shafts for mine. It won't go round corners you say? Can you elaborate a bit?
from what ive learnt on here, you should only use them if the car has been lowered alot (think anymore then 25mm-30mm) cos originals may pop out? you'll find out when you try to fit them, i couldn't get mine to fit because it hasn't been lowered enough
okay, thanks. Cars on eibach springs, about 25 to 30mm drop incidently. Only one way to find out I guess...
JoeyBoyden
04-01-2024 02:36 PM
