2wd sapphire floating at speed
1 Post
Hi everyone,i've got a 2wd saph when i get past 150 mph on a track the steering is vague,is there anything i can do to keep the front end down so the steering works propely???
Puller of the Wrench
I have a front undertray that I've fitted. Has a slight angle on it and forces air into the engine bay. Double duty is that it pushes the front end down a bit.
150mph in a saff and the front end is going to be a bit vague. You are doing about Mach 0.2 at that point.
Mounts to the bottom of the radiator.
1 Post
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
