2wd rear axle removal
Hi
I need to find out the best way to drop rear axle, beem, diff and what else will need to be dissconected to do so.
Cheers.
Cheers.
you will need to disconnect the brake pipes, abs sensors and the handbrake cable, also the shocks. Then just undo the two outer mounts and the diff mount and it should drop out.
09-10-2015 07:38 PM
FlashRS
13
31-08-2015 06:02 PM
