zetec turbo has peak power only at 5200 rpm
hi,
why dosen't my zetec turbo rev?
its got 270 bhp peak at 5200, that should be more like 6700 if you ask me. it running 20 psi,
i think its a flow issue, maybe my manifolds of turbo choice, but when you drive the car it really runs out of puff and you have to change gear to make it go again. my limmeter is only set at 6200 and i hardly ever reaches that.
my spec is as follows;
8;1 comp ratio with accrilites
modified escort rs turbo exhaust manifold
rs18i inlet manifold (aluminium type)
stage 3 t3 turbo
2.5 inch through exhaust
standard 2.0 cams
ported head and manifolds
uprated valve springs from area six (3 years ago)
i recon it mite be the s2 exhaust manifold not flowing enuf, and/or the stage 3 t3 turbo a bit too small??
the car really goes well, but just reaches a natural govener too early.
any advice is appreciated, thanks
stage 3 t3 turbo
standard 2.0 cams
hi,
stage 3 t3 turbo
standard 2.0 cams
stage 3 t3 turbo
standard 2.0 cams
the standard escort exhaust manifold has been flow tested at 350+bhp so it wont be that mate.
what managment is it on? and as crazycage said what injectors you using?
its running bosch 803 wit around 70% duty max,
megasquirt ecu,
its theearly silvertop zetec from m reg mondeo
valve timing is tandard except i advanced inlet cam verry slightly,
and trap speed over the line was 107 mph
thanks for the replies, i stilll think its turbo being too smallon exhaust side, ithink its a .48 housing on a stage 3 t3??
megasquirt ecu,
I'm thinking that the advance on the inlet is the wrong choise for multiple reasons.
Generally if you want more power higher up on the rev range, retard.
If you are running a small turbo that creates high back pressure, you want the exhaust and inlet to have very little overlap to avoid reversal of gases --> retard inlet or advance exhaust.
If you have boost pressure in the inlet flow, you don't need to use the complete geometric compression ratio, because the amount of lost compression pressure can be subsitited with boost. So, it's ok to close the inlet valve a bit late. --> retad inlet.
Even on the RST when it was introduced, the cam was the same as in the XR3i, but retarded with a different pulley.
Bodger of Blackburn
cba reading all the replies, but sounds as if the cam profile isn't aggressive enough or the timing of the inlet is too advanced, similarly the exhaust cam could be to blame.
get it on the rollers and start moving cam timing a little.
what valve springs are you using also?
maybe they can't handle higher revs.
thanks to JesseT, my zetec turbo now revs to the limmeter! i had the rocker cover off today and retarded my inlet cam (its just a nats cock before standard now) took it 4 a spin, and wheel spin all the way to the limmeter... great!, in the wet tho
so thank you, much happier now
YES I KNOW I CANT SPELL
Cameron
14
09-08-2015 06:28 AM
