4x4 exhaust manifold or 2wd ??
hi,
basically im pissed off with with my 2wd turbo manifold as the bolts keep coming loose (the 4 x m8's) despite several attempts to secure it, iv tried lock tight, spring washers, stud and nuts with spring washers.. just about every thing, its got a turbo damper too. its melted my wiring loom now and so my sollution starts here.
any sujestions??
can i just put the 4x4 one directly in place? i heard these dont flow as good tho and my bhp is over 400 with 2 bar boost. would the 4x4 manifold cope with this?
any sujestions is greatly appreciated,
any sujestions??
4wd will fit, but starts to be a limit around 400, compared with 2wd, though it will boost earlier with 4wd one.
There is no logical reason why the nuts should come undone.
Try making your own K nuts, only need a vice, takes minutes and works perfectly.
can it be migged? as its cast isnt it?
cheers for all your info
rsstav
Ford Focus RS Parts for Sale.
20-08-2015 07:45 AM
