| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
![]() BANNED |
So you have a FRS mk1, in which the tacho reads 1/2 ?
Hard to see how this can happen with the correct tacho, the reason why they read 1/2 is because they are for a conventional, ie non coilpack ignition system. So the std wiring will be ok for this. If I assume you are using some aftermarket tacho, most have switches to suit different cylinders amounts, so switch to different setting will sort it. I don't know if this will work but is something I thought about before, and that is to take a reading from BOTH side of the coil negative, each through a rectifier diode, ie 1N5408, this will then double the signal, as the std coilpack tachos only sense one side. tabetha |
#3 |
thanks for the reply tabetha
i need the rpm signal for a turbo timer, ive tried everything i can think of but had no luck. i will give your idea a try and will let you know how i get on! I wonder how other people who have fitted boost controllers, turbo timers and an additional tacho that require a rpm signal have got round this problem? ive done lots of searches and other people have had the problem. |
#4 |
![]() BANNED |
I can't see why it would matter what the rpm reading was for a turbo timer, so long as it's getting a feed ?
tabetha |
#5 |
it has 'cut off' switch where once the timer has started its count down, if it goes over 1800rpm it shuts off straight away. plus it displays the rpm so want it showing it accurately. Im expecting them rectifier diodes tommorow so il let you know if it works.
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| RPM signal for Zeitronix AFR unit | JanDK | Ford Escort RS Cosworth | 0 | 30-01-2008 09:07 AM |
| RPM signal AND neutral position signal | Robi81 | Ford Fiesta Rs1800 & Rs Turbo | 4 | 21-07-2006 07:55 PM |
| HELP. Speed signal and RPM signal | andysa | Ford Escort RS Turbo | 0 | 06-03-2006 10:31 AM |
| Signal Orange and Signal Amber pics required urgently please | S1 | General Car Related Discussion. | 20 | 17-12-2005 08:22 AM |
| what pin is rpm signal on a l6 coilpack ecu | Matt | General Car Related Discussion. | 3 | 17-10-2005 03:19 PM |
