Forge dump valve probs!
05-10-2009, 06:03 PM
Hi guys i need your help on this one! Hubbys just bought me a forge dump valve for my mfi series 2 escort rs turbo and my car wont run with it!!! It wont tick over!!AHHHHHHHHH it runs like a bag of shite is there a reason for this?? Do mfi and efi vary??
Cheers in advance!
05-10-2009, 06:13 PM
yea put a twin piston type one on NOT the single one you've just fitted!
05-10-2009, 06:21 PM
05-10-2009, 06:27 PM
Guys apparently it is a twin piston! HELPPPPPPPPPPPPP
05-10-2009, 06:36 PM
Send it back rst's run better without one anyway.
05-10-2009, 06:42 PM
Quote:
Originally Posted by
lmmrst
take it off and look up the tube part and see if there's a rod inside!
05-10-2009, 06:54 PM
Alvyn
No rod mate!
05-10-2009, 06:59 PM
lmmrst
No rod mate!
then thats a single piston type then which = NO good for you!
05-10-2009, 07:01 PM
Alvyn
Cheers mate will pop it back to my chum at forge! If i get a dual will it work?? Cheers lisa
05-10-2009, 07:07 PM
lmmrst
Cheers mate will pop it back to my chum at forge! If i get a dual will it work ?? Cheers lisa
yep 100%
think this is the type you need to get
Forge 6-bolt type piston dump-valve
06-10-2009, 06:08 PM
Alvyn
yep 100%
Cheers mate all swapped over and car runs but havent taken it out yet!! Cheers kindly for info matey! Lis x
01-11-2015 06:53 PM
gcfcos
59
06-10-2015 05:04 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
richierich1986
18-09-2015 03:29 PM
