| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
YES I KNOW I CANT SPELL
lol more fuel wont all way make it faster you no? sounds like pub talk to me
__________________
" im special,, excuse my spellings" |
#3 |
#4 |
sum1 must know.....
#5 |
on the back of my pump (mk 6 escort van) thier is a little allen key with a lock nut on it i loosened the nut and tweeked the allen key out a bit
it did feel alot better after this i even raised the rev limit a bit which also made it a bit better |
#6 |
![]() BANNED |
What pump is it, if a LUCAS/CAV it is a doddle, and will make a HUGE difference, mine went like stink and did a indicated 112mph after a fiddle, was a n/a 1.8 diesel escort(mk4), also still did 55mpg, took all of 5 minutes to do.
Look on the front of the pump and see if there is a big hex shaped cover about the size of a 50p piece ? tabetha |
#7 | |
Quote:
#8 |
![]() BANNED |
It does indeed, should be around a 10/11mm nut surrounding a allen screw ?
tabetha |
#9 |
#10 |
my pump is lucas, and is the same as the 1 here
http://cgi.ebay.co.uk/Ford-escort-va...d=p3286.c0.m14 |
#11 |
11000+ post super hero
it works on the vauhall td isuzu engine. unfortunately it doesnt work on the shitty vauxhalls own engine.
__________________
![]() stage 3 cosworth converted bmw e30 touring. xbox live evilfuzzy2011 |
#12 |
![]() BANNED |
That certainly looks like the kiddie, and your description sounds ok, they have obviously just changed the locking nut bit.
tabetha |
#13 |
so i just turn it in or out to turn up the fuel??
#14 |
You will see if you adjust the screw. One way it will limit how much the throttle will open. You want it so it opens more. I done it on my Fiesta diesel, it made a big difference. But the shit that used to come out of it
__________________
#15 |
im gonna play wi it the now
#16 |
__________________
#17 |
hasnt made much differance, turning the 8mm nut :s is here a detailed "how to" anywhere?
#18 |
anyone ???
#19 |
can you smell purple?
Trader Score: (0)
Location: normally dewsbury west yorkshire, but i could wake up anywhere!
Rep Power: 3 ![]() |
check out this -
i know its for a pug but its the same thing. done this on my mates mk2 mondy. works well. if yours is just an n/a version, just do the max fueling screw. a STRONG 4mm allen key is needed. dont use a shit one coz if it snaps your fooked! |
#20 |
hi i have a mk 6 escort van, and i want to open up the diesel pump aswell. i ripped off the safety plate which stops you tamperin where the injector pipes come out and found a allen key thread with a locking nut and wound it in and out but either way it never made much difference. what is the big hexagon bolt on the pump for? would that have anythin to do with tunin the pump up? if anyone has any idea of tweakin up the diesel pump please let me know
#21 |
Trader Score: (0)
The stud your playing with, does it need a 13mm spanner to release the locking screw? Uf so this us the "on boost" which wont make a hell of a difference without the turbo pressure turning up to match.
Youll need the max fuel screw turning up too to see any descent gains.
__________________
DIESEL POWER "if there's no smoke, there's no poke"
#22 |
where is the max fuelin screw on the pump?
#23 |
Trader Score: (0)
it is inside the pump, theres a black cap on the front of the pump. remove this, some diesel will spill out.
using a mirror, have a look inside. jack the car up and put it gear, turn a wheel until you can see the allen stud inside. turn this clockwise about 30 - 40 degrees
__________________
#24 |
ok ill have a go at that tomorow or sunday. is it an easy job and will it make much difference?
#25 |
Trader Score: (0)
it does if its all done properly. is your a N/A, TD or TDI?
i did a sort of guide here http://www.eodc.co.uk/forums/index.p...de-and-tuning/ check the video links out on there too
__________________
#26 |
its a n/a engine. so you can see why i want a bit more poke
#27 |
Trader Score: (0)
__________________
#28 | |
Quote:
#29 |
what do i need, to be able to fit a turbo and intercooler off a mondeo onto my engine? where would i find the oil feed for the turbo?
i no its not a good idea but i fancy givin it a go |
#30 |
#31 |
#32 |
fitted a turbo to my n/a engine. it came of a fiesta di engine. but the waiste gate doesent open as the engine revs up like it should. it justs stays shut and all the exhaust gases are forced through the turbo and the turbo ends up whistlin its head off. does anyone know whats the cause of this?
#33 | |
Trader Score: (0)
Quote:
soak all the actuaor rod etc with wd40 and let it soak, if youve bought a tdi setup off an that been exposed to the weather it might be rusted up. out of curiosity, did you get the td oil pump aswell?
__________________
#34 |
ok ill give it a go. no i didnt get the oil pump, i found an oil feed rite next to the oil filter so i got the oil feed for the turbo from there. you'll see that it is blocked up with a 1/4 thread with an allen key head in the end of it.
#35 |
do you know how to lower a mk6 escort van. i've put the axle on top of the leef springs before when i had 14 inch wheels on and it was fine. i've now got 17 inch wheels on it and i dont know if they would rub or no??
#36 |
Trader Score: (0)
lucky bleeder, like rocking horse poo to find an n/a with the turbo feed on the pump
__________________
#37 | |
Trader Score: (0)
Quote:
the front usually isnt a problem if your wheels are 7" wide (7j) you should be fine, if not get the rear arches rolled to give you extra room. i know mk1 rs focus wheels and cosworth wheelds rub as there 8" (8j) wide
__________________
#38 |
dunno how wide they are in inches but there 215s?
#39 |
Trader Score: (0)
__________________
#40 |
okie dokie.will try it over christmas some time. cheers boss
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| escort diesel van | john.jones | Technical help Q & A | 5 | 12-12-2010 08:44 PM |
| mk6 escort van diesel pump solenoid | RS 5tu | General Car Related Discussion. | 4 | 21-10-2008 05:05 AM |
| what diesel pump on 1996 escort van? | glenbat | Technical help Q & A | 0 | 25-11-2005 10:11 PM |
| ESCORT DIESEL VAN | barney | Cars & Parts Wanted. | 6 | 01-11-2005 10:47 PM |
