Pull to the right - Play in something
26-09-2009, 09:19 AM
My RS seems to pull to the right during hard acceleration, and if up on the ramp and you grab the front right wheel it has some play in something. I presumed both are connected?
26-09-2009, 09:50 AM
any idea where the plays coming from? sounds like either lower suspension arm bushes/ball joint or track rod end/rack... more than likey the ball joint though
26-09-2009, 10:02 AM
renew all the wareable bits, they are pretty cheap anyway.
Brother just done it on his, made a pretty considerable difference.
26-09-2009, 10:16 AM
Check your anti roll bar is bolted up tight!
26-09-2009, 10:34 AM
I'd be looking at the tca ball joint first, these may pull anyway due to torque steer to a certain extent.
26-09-2009, 02:21 PM
Yea, my old one torque steered but it was running more power. This is fairly standard. Ill check the ARB is tight then the tca's
28-09-2009, 09:32 PM
Had a closer look today, its seems there is movememnt in the ball joint on the end of the tca.
29-09-2009, 07:56 AM
Roosie in his xr2 track car managed to do a few races with a knackered ball joint!!
29-09-2009, 08:14 AM
When changing the tca ball joint can you just count turns to take off and re-apply new part counting the turns on? Is this suffice?
04-10-2009, 08:36 AM
500bhp Cosworth in making
Quote:
Originally Posted by
Dont i know it oulton park had a knackered ball joint on warm up lap lost a good second a lap but still managed to hold it off and finish 5th
04-10-2009, 02:46 PM
Hiya Roosie,
Did he turn up for the truck ?
I'm just about to reset the software for monday afternoon, will bring my ftdi as well.
04-10-2009, 02:48 PM
*** Sierra RS Custard ***
Track rod end would be the first thing I would check.
timsrs
13-11-2018 11:48 AM
tankybaby66
06-02-2016 02:24 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
21
14-09-2015 06:38 PM
