Fuel Pump
Old 26-09-2009, 12:15 AM
djchurch2001
djchurch2001's Avatar
Default Fuel Pump
recently done a turbo conversion on my escort xr3i to and rs turbo i removed the loom and engine from a working turbo but not the car will not run, starts fine then dies straight away. The fuel pump does not sound how it normally should and sounds like it is struggling not the normal high pitch buzz. How do i test that the pump is working and could it be that i have not connected the loom up correctly.
Old 26-09-2009, 10:41 AM
More detail with this question(than the other thread), it sounds as though the pump could have sucked some crap up from out the tank, especially if run low.
I believe these are external pumps ?, if so you can take the wires off, and with a battery pack or similar reverse the power to the pump, this often dislodges any crap in there as it then flows backwards, but if this works of course it means the tank needs cleaning out.
Reversing it will do no harm, for about 10 seconds at a time, you will actually normally hear the bits of crap getting booted out.
JK12
33
26-04-2021 12:09 PM
155lee
27-10-2015 04:55 AM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
tib2220
14-09-2015 12:33 PM
Quick Reply: Fuel Pump
