PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 20-09-2009, 09:50 PM   #1
DANIEL p
LOVE FORDS
DANIEL p's Avatar
Trader Score: (0)
DANIEL p is on a distinguished road
Default no battery or oil warning light
i recently put new engine in my s2 and when i turn ignition on i have no battery warning light or oil warning light i no the alternater is good as it was on my old engine and worked fine i also no the bulbs in dash are good any ideas pls
DANIEL p is offline   Reply With Quote
Old 21-09-2009, 11:11 AM   #2
Trader Score: (0)
tabetha will become famous soon enough
Both these relay on earth return to light the bulbs, so I would check the earth strap first is fitted tightly, then earth the thin blue wire out on metal/engine to see if bulb works, and same for the oil pressure wire.
tabetha is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
help!battery warning light fezzajsy Ford Sierra / Sapphire / RS500 Cosworth 9 08-05-2008 07:03 PM
Battery warning light stays on bunjeeman Ford Escort RS Cosworth 5 03-01-2008 03:10 AM
what pressure does standard Oil warning light come on at???? pee vee General Car Related Discussion. 12 14-04-2006 06:00 PM
battery warning light??? CraigJ Ford Escort RS Turbo 12 15-02-2006 09:54 PM
oil warning light advice please ian.gordon Ford Sierra / Sapphire / RS500 Cosworth 3 09-09-2004 09:30 PM
