99 Escort LX SOHC fuel filter replacement
Hi there, I need to replace the fuel filter on my 99 escort LX SOHC. I haven't done this before so I'm a little unsure. Do I need to relieve fuel pressure by disconnecting the fuel pump relay? Or can I just replace the fuel filter? thanks
Disconnecting the relay will NOT let the pressure out.
By the time you have undone the clips, etc holding the pipes onto the fuel filter all the pressure will be gone, BUT if you are still worried, on the fuel rail, that feeds fuel to the injectors you will find a shrader valve, a valve the same as on your wheels.
This is to take fuel pressure readings, but if you put a rag around a drill bit or similar and depress this it lets all the pressure out, make sure the rag is around, as it's a good squirt.
I've never needed to depressurise when doing a fuel filter yet, maybe wait a second or two till it stops dribbling after taken connectors of each end that's all.
