Brake upgrades - 4 pots, Pedal Box's and Biasing
Just after some brief advice really, I would like to upgrade the brakes in my Fiesta Zetec-S at some point this year, it's currently running 300mm Mondeo Mk3 calipers and ST170 discs upfront, and a 258mm Focus set-up on the rear, however they are pants, and I have decided just to go all out with an upgrade.
I would like to go for a set of 4 pots up front, and have only just started looking, but I know I can pick up a set by Wilwood or Hi-Spec. Any pro's or cons of each set up? The Wilwoods did confuse me a little, as it's all sold in components.
Also, I have been thinking about whether it's worth going with a pedal box and biasing valve, if I did decide to go with this, what else would be needed apart from the box? I have seen a kit for about £200 that includes the resovoirs, but would I need to run braided lines (not the ones to the calipers, aeroquip or whichever they are ) to see the biggest benefit?
The car is intended to be used for Fast Road and track, so please no comments about "it's only a Fiesta" as it will be more than that. Also an indication of rough price would be great also.
Cheers, Rob
Cheers, Rob
No real feel in the brakes, not as sharp as I would expect, my previous ZS with uprated discs and pads felt like a better set up.
I want a set-up that will offer alot of confidence, and also real performance when needed.
I've got a set of 15" Compomotive TH's, so hoping they should clear, was told that Evo's have been known to run 320mm brakes with the same wheels.
