oil cooler
oil cooler
hi...
what size cooler do i need for 400bhp cosworth that is 50/50 road and track, the standard water cooler has been removed so the oil is 100% cooled by the air..
and also wheres the best place to buy one..thanks pete
I'd get one from Matt Lewis 01543 448848, try and get one with a thermostat if you can, as this will speed up the heating of the oil, and control it when temps are lower.
I'd suggest a 13 row would be fine, wherever you put the cooler, try and panel it in so the air has to go through it, like in lower part of front bumper.
