| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Technical help Q & A Got A technical problem with you car? Keep it in here where the techies hang out and we will try to solve it for you!! |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
Go to a scrappy and look for a 2.0 16V Ghia ..
Looking @ £20 a side, No more TBH ... You will need: 1' Spindal - / - Hub - / - Caliper's. 2' Backing plate's. 3' Discs/Pads. 4' 2.0 - / - ST170 - / - RS Focus Rear Hose. 5' ST170 - / - 2.0 16V handbrake cable. 6' Maybe the ABS sensors if Applicable. 2.0 16v = 255mm Discs. ST170 = 280 mm Discs. RS focus = 280mm Discs, +8mm off-set. Depending on front brake set up go for the 2.0 16v. (Cheaper) I'de say £80 for the conversion depending on where you get the Handbrake cable, Discs and pads. |
#3 |
cheers for the help. how much do u think the calipers would cost? they seem to be the most expensive on ebay, but how much from the scrappy?
#4 |
Ring around a few local scrappies and get an idea of the price, bit of bartering may help
#5 | |
Quote:
I have a spare pair of calipers on 2.0 16v carriers .. (255mm disc) See your in Durham as well .. Drop me a an offer if interested? |
#6 |
#7 |
where are the best scrappies in the North East? i heard that theres a ford specialist one somewhere?....
#8 |
I converted my drums of my focus 1.8 to discs about 6 months ago.
I brought a full st170 rear axle, with brake discs calipers etc fitted from ebay from a scrapped car for £200. Than i just had my old rear axle swapped with the st170 one at my local garage. I had a look around first, and this was the cheapest and easiest way i could find. hope this helps |
#9 |
same as i got a axle off ebay for like 120 quid swaped it over myself,
didint swap the whole axle just the brake side of things, took about 3 hours but cost nothing. had 2 take a blow tourch 2 1 of the nuts tho, tight as!! that was done about a year ago along wiv a st170 300mm front conversion, again not 2 involved. plus 6 pot wilwoods fit rite up!! no trouble stoppin now. ![]() puma speed sell brake kits front and rear. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Focus rear disc conversion. | mercury grey minter | Ford Focus RS | 21 | 22-04-2011 06:46 PM |
| Escort van rear drum to disc conversion. | darrendickinson | General Car Related Discussion. | 5 | 11-02-2011 11:49 AM |
| Focus rear disc conversion ?? | mercury grey minter | General Car Related Discussion. | 5 | 01-03-2009 01:18 PM |
| mk1 mondeo rear disc conversion | skrats | Technical help Q & A | 3 | 01-12-2008 07:47 PM |
| rear drum/disc conversion | Doddie | Technical help Q & A | 0 | 03-12-2007 11:23 PM |
