rs turbo fuel pump relay
hello just wondering if anyone can help me i have a pink fuel pump real but instead of pin 87 i have 54 will this still work here are some numbers of it if it will help
68125
8566 9p704aa
68125
8566 9p704aa
Are you sure ?, number 54 is TRAILER signal for lamp combinations and trailer stop lamp.
Pin 87 is load ie device you are switching in this case the fuel pump.
If you want to use it just check that when 85 and 86 are put to neg and pos it allows current to flow from 30 to 54, if pins same orientation as old one will be fine.
yeh its definately 54-15 and all of them have that type of thing here are all the numbers 31- then 54-15 1-3 15-11 30-28 is this the wrong relay thanks for the information
at the minute my fuel pump relay is hard wired aswell but it seems like it floods the car by running constantly unless you start it straight away i thought this could be the cause
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
