turbo is not well
26-08-2009, 08:48 PM
turbo is not well
my escort rs turbo starts aruns fine with no smoke i take it for a spin , put my foot down it boosts then splutters big bang and a cloud of blue smoke, just had a recon turbo fitted so what could it be ???
26-08-2009, 08:56 PM
Quote:
Originally Posted by
maestrouk
you sure the motor is timed up right?
not running too much boost?
26-08-2009, 09:01 PM
not well
LHD220Turbo
well it runs and revs perfect and drives ok just once the tubo kicks in on release i wound down -31 and still doing it ?
26-08-2009, 09:03 PM
its hard to say mate, whats the spec of it?
26-08-2009, 09:06 PM
spec
andy130
standard, all ive dne is put a recon t3 on it like i say no smoke at all on driving like miss daisy the second i turn into lewis hamilton it spluttes big pop and blue smoke then clears again
26-08-2009, 09:08 PM
maestrouk
What do you mean wond it down? To reduce boost you need to make it longer not shorter.
JAmes.
26-08-2009, 09:10 PM
wound it down
jammy86
JAmes.
yeah thats just my way of saying winding te boost down mate by screwing the arm out longer
26-08-2009, 09:13 PM
did it do this before the turbo let go? could be leads,plugs
26-08-2009, 09:14 PM
andy130
i bought the car with the turbo gone so iwouldnt know ill give that a try
26-08-2009, 10:44 PM
Bodger of Blackburn
sounds timing related to me.
27-08-2009, 12:07 AM
Did you get the turbo re-coned? or bought it re-coned?
could be one of many things, speaking from experience of similar symptoms
weak spark
timing's out
-31 actuator on std ecu (too much boost)
blocked/squashed vacuum hose to the ecu. ( a favourtie of my car )
27-08-2009, 06:04 PM
Chopshop85
weak spark
timing's out
i got it reconed ill give what yuv said atry an i will letyou kno how i get on thanks for the info
27-08-2009, 06:19 PM
ok man, let us know if theyre any break throughs
29-08-2009, 02:27 PM
Chopshop85
right running better i wound out te actuator but now it seems t b over boostin all te time ?
29-08-2009, 08:15 PM
Have you got a chipped ecu in it?
29-08-2009, 08:30 PM
Chopshop85
yes
29-08-2009, 08:44 PM
hmm could be one of many other things then. i would strongly suggest winding the boost off completely until you can get a tuner to have a look at it. heard way to many sob stories of people who try to do a bit of home tuning and a few weeks down the road picking bits of theyre engines up off the road.
30-08-2009, 08:18 AM
Chopshop85
top stuff ta
30-08-2009, 12:19 PM
drop it up to mine ant i can have a look for you,
31-08-2009, 03:32 PM
turbo
andyuk
text me were your livin now ill drop it in
JK12
33
26-04-2021 12:09 PM
RSBryden
06-09-2015 08:39 PM
cozzzzy power
04-09-2015 08:14 AM
turbowag
03-09-2015 08:07 AM
Jerry Ryan
02-09-2015 08:02 PM
