wiring help please!
wiring help please!
just in the final stages of fitting omex to my saph and now fitting the relays.
am i right in thinking i need to put a fuse along side the relays? (got 1 relay going to ecu and one will be used for fuel pump.
so would i be correct in putting a fuse in the switched (ignition) feed to the relays? what amp fuse should i be using? using the standard ford 40 amp 4 pin relays if that makes any odds?
Ford had the fuses the supply to the relay, not in the switched feed.
For wiring diagram: http://www.siipicossu.com/manuaaleja/manuaalit.htm
Mark RS
12-10-2015 06:01 AM
