Mondeo TDCi 2004 turbo help please
A friends mondeo has thrown up some fault codes on the diagnostics at our local garage, due it not boosting whatsoever
They are P132A and P132B
Apparently the boost control position circuit.
Ford have been as useless as ususal and said just buy as new turbo, that will cure it £1000 please.
To be honest that was a little worse than we had hoped. dDoes anyone know anything else these codes mean???
Would be most helpful, Thanks
Scott
Scott
i'm pretty sure thats going to be a problem with the vnt part of the turbo, if the turbo has a vacuum actuator then it can be fixed, if its an electronic actuator then its probably time for a new turbo.
when you find out what actuator it is call someone like Midland turbo for advise.
Matt Baxter
16-09-2015 08:30 PM
actuator, control, controller, electric, electronic, england, ford, mondeo, northeast, p132b, problem, tdci, turbo, turbocharger, vacuum
