rs turbo running crap HELP !!!
HI PEEPS GETTING MY SERIES 2 R/ROADED 2MORROW ITS RUNNING REALLY SHIT I BOUGHT IT AS A NON RUNNER REPLACED THE METERING UNIT STILL DID NOT RUN SO I TESTED THE FUEL ECU AND IT TURNED OUT TO BE FUCKED, IVE REPLACED THIS ,THE INJECTORS, DIZZY ,COIL AND ROTOR ARM , AND REBUILT THE TOP END WHEN THE CAR REVS AT STANDSTILL IT SOUNDS OK, BUT WHEN I DRIVE IT ITS LACKING POWER/MISSING BIG TIME IT SEEMS TO GET WORSE WHEN IT STARTS TO BOOST, IVE HAD THE INJECTORS OUT TO MAKE SURE THERE ALL GETTING FUEL THROUGH AND THEY ARE I DONT KNOW WHAT ELSE TO TRY THE CAR WONT START WHEN COLD BUT IF YOU PUSH THE FLAP DOWN SLIGHTLY SO IT INJECTS A LITTLE FUEL IT FIRES UP OK ,THEN ONCE WARM EVEN AFTER SITTING FOR AN HOUR IT FIRES FIRST TURN. IVE BEEN TOLD THIS COULD JUST BE THE METERING UNIT SET UP BADLY HAS ANY1 HAD SIMILAR TROUBLES AS I DONT WANT TO DRIVE ALL THE WAY TO THE ROLLING ROAD 2MORROW TO BE TOLD ITS FUCKED AS ITS £75 AN HOUR AND 120 MILES FROM ME AS IM OUT IN THE STICKS ,CHEERS GUYS
big_Rad
15-09-2017 09:36 AM
Matt Baxter
16-09-2015 08:30 PM
