2wd Cosworth not firing
Hello peeps anyone got an idea about this
My mates sapphire which he has had for about 7yrs had developed an intermitent problem and the last report was whilst conering it started to miss so he levelled it out a booted it.When it came on boost it did it again and then died.It was left for about half an hour and fired up and then died again.Anyway when you are turning it over it sounds like its trying to fire now and again.It was pluged into the computer and it gave the fault of crank sensor,that was changed but no joy.Every other sensor was changed and a different ecu and ignition amp used but was still the same.Another loom was purchased but still the same.One engine loom was pluged onto another car with my mates ecu and it starts and runs so that was then placed back on the car but the fault persists.The alarm immobiliser was disconnected so its not that either.The pulse to the injectors is weak and very random,this has been tried with a bulb plugged into the loom.The dizzy has been looked at too.Getting a bit fed up and stumped now,oh yes the bottom pulley has been removed and inspected and looked to be good but the bloody computer still gives the fault of the crank sensor if I think of anything else thats been done I will post back.Its a bit of a head scratcher,thanks everyone
There is power to the relay for the ecu and have bypassed the switched power,I didnt do it personally so I dont know about the earth side.Thanks.
I have sat and thought about this for a bit,if all the engine loom and ecu were used on another car and worked coming back to the original car and wouldnt obviously its got be be something still on the car.The phase sensor is new and so crank sensor so what do you guys think about the dizzy ? maybe the wiring is breaking down ? would I be right in saying as its the only electrical component left on the car that would stop it from firing/running ?.
One more thing to stop me sounding like a total dumbass it wasnt a just a "bulb" that was placed in the injector plug it was a noid light,I just didnt know what it was called.
Thanks for the replys so far keep em coming lol . I dont know what gaps on the phase or crank and as far as know the leads are sound.The car is going to be looked at again tomorrow and I am off out now to get some beer .
I will post when I know answers to question or it gets solved.
I would look at two things
Phase sensor
And if you use a carger while the ecu is connected the chip in the ECU
i didnt bother reading the post but from what yu said i had these cae the problem
Phase sensor
i had a similar probe on my fiesta cosworth.it was the phase sensor underneath the rotor arm. sometimes the wiring can age and play up under load, mine actually had no insulation left and was sparking out. i got a new one from woodford motorsport cheap and did the job. also worth putting a group A coil on too! cope better with load
hope that helps
hope that helps
hope that helps
hope that helps
Update on this,BigErn wins I didn't check this but thats what the problem was, even after all the fuckin about they did.The switched ign had fried to the ecu,I thought as this had been bridged but no I was wrong.lesson to everyone,check everything yourself and believe no one
09-10-2015 07:38 PM
FlashRS
13
31-08-2015 06:02 PM
