Mk6 escort wheel stud replacements - help!
Fitting some 10mm wheel spacers to the front of my Escort GTi but come across a problem.
I assumed the studs would just knock out, but i appears there is something behind them stopping removal. In the middle of there hub there is a large 32mm bolt which i assume removes the hub assembly?
The picture below shows the studs and the object behind stopping removal.
Can anyone tell me how i go about replacing my wheel studs?
Thanks,
James
Thanks,
James
