Idle Problem That Wont Go Away
hopefully someone can help me here as this is really doing my head in now
basically my Si will hang at around 1500rpm and seems to take ages to drop to a normal idle speed. when i first start the car it is fine but it is only once i move off, for example when i drive off and come to standstill it stays at a high rev but will drop eventually. it doesnt seem to matter if the car is cold or warmed up nicely either
i have cleaned the ISCV, changed the TPS, cleaned the MAF, had inlet checked for airleaks, throttle body cleaned and recently changed the speed sensor but it still does it
anyone got any ideas??
John
John
fella try the coolant temperature sender either in the top hose or on the head but first disconnect the battery for half hour see if that puts it right if it does get it scanned but u will need to wait until the fault comes back first
should there be any difference in the sound of the engine when you unplug this ie should it drop revs etc..?
i have got a brand new one that i am waiting to buy
will have a look at the temp sender but i have tried the battery disconnected route and it didnt do anything
Is it when you start your car from cold it idles normal but as soon as you touch the throttle and release it revs up by itself and as soon as you drive down the road it stops?
I am thinking CTS as it seems temperature related an incorrect CO mixture can also cause this.
Martin
Martin
Martin
Martin
basically when i touch the throttle it sticks at around 1500rpm for too long if you know what i mean
Has a large member
yeh the revs will drop and the car will either idle so low it will try and cut out, or (like mine) it will find itself after 10-15seconds. although it'll still idle very low so you will have to give it a few turns on the idle speed screw next to the inlet. as soon as i unplugged it i rev'd it up and it dropped back down fast like it should unlike before
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
