SUBARU WRX IMPORT CLASSIC L reg HELP PLEASE GUYS prize to who ever gets it right :P
Right guys my best bud has a L reg 94 wrx import and has spent a fortune trying to fix this problem ok so here goes he has got new coil packs,plugs,loom,engine cooling temp sensor,crank sensor,air flow metre but what the major porbs is its holding back when warmed up can anyone help please as he has spent a small fortune on it tabeth you know what it is as your the daddy
checked that its the proper gap and bought a spare set incasethat wouldnt be the problem whem heated upnot that come on lads lets see who is the daddy who can sort this
FROZEN WHITE FRS No2676
1 Post
If its knackered when its cold its fine once the car warms up it wont rev cause it blocks up had 1 or 2 at work thats done this and loads of zetecs ones only a stab in the dark tho mate .
cosworth gimp
air leak on inlet side ?? or boost leak perhaps
metal expands when warm at different rates ,had a mk1 xr2 that ran fine when cold but once warm the inlet manifold warped weirdly so drew in air
just a thought prolly not right but maybe worth a check
also maybe a faulty chip
Check the pipe under the intercooler, its y shaped, they can crack and split here and also the gaskets go and cause it to hesitate. Happened to mine a while ago, quite a popular problem apparently
When you say holding back what does that mean ? is the turbo boosting and holding boost ok or is it a speed issue... it could have a limiter still fitted.
As said it could be loosing pressure with a leaking joint on a pipe as well.
Is there a boost gauge fitted if so ask him what it is boosting to, not sure what an early wrx should be doing but a uk turbo for example peaks at 0.98 on a standard map.
You can also do a diagnosis test on the car by plugging some wires together under the dash. has the check engine light come on? does it come on then go off when the ignition is turned on? someone could have removed the bulb if its been having problems and he has recently bought it possibly
