Breather pipe
Breather pipe
hi iv got a 1987 rs turbo only just had it as a none runner does any one no why you need a crankcase breather pipe? because it does not seem to have one?HELP!!!
It needs one to continue the air flow. Without one it will not drive due to a huge airleak, unless it's running a bailey breather pot that's aired to atmosphere.... But even then it'll still need the breather hose!
If that's the reason it's a non-runner, you're laughing! £10 fix
BREATHER
Ok m8 its got no black plasic pipe off the left hand side of inlet just a boost pipe blocked off but iv noticed a nipel on the left side off the head beathe pipe it looks like a pot with one nipel spair?could i use the boost pipe?becaues the ones on photos iv seen seems pastic not rubber!!
07-10-2015 12:56 PM
