2 wd drive saph cos running prob??
as above.... wont start unless your pumping the throttle. like lack of fuel. once it does start if you stop pumping the throttle it dies and wont idle....foot to the floor it dies too. new fuel pump, filter, regulator, coolant temp sensor, map sensor...... dont seem to be drawing air either............. ????????????????
cheers
cheers
need more imfo tbh m8! was it running properly prior to the problem or have you got the ending of some one else tampering etc!
what's the spec of it? has it got the correct chip to run the injectors/map sensor that are present?
yawiejon
15
09-08-2015 06:36 PM
CabrioTurbo
01-08-2015 11:04 AM
