T35 oil feed and other info
Hi All,
I'm currently gathering the bits to put an Ecosse T35 onto a 2.9 V6 cossie. For the oil feed I'm looking at taking it from the pressure switch via a T piece - So the first question is what oil supply hose to use. I think the 4x4 saph hose might be too short but would a 2WD hose be suitable - connection wise are these all standard? - Are they 1/4 or 1/8 BSP on both ends and would it fit the T35?
