1.6 cvh xr2i ignition light,s prob s
ok hi people my car just wont turn off wen i turn off the key if i stall it with the ignition off it stalles but the ignition lights stay on.?.. anybody had same happenings as wat ive got.any help wanted. common fault may be but i luv my car old skwl i expect ha. help me pls
Could be a stuck power feed relay, these are often labled/termed PCM in the fusebox, but next time just tap all the relays in the box as something clearly is keeping the system alive.
Dr. Ickxs
15-09-2015 10:15 PM
