RS2000 4x4 rear brakes
Hi there , ive got a problem with my o/sr brake ! As in the damn thing doesnt want to work ! All the others work fine as can be seen by the shiny discs , but the o/sr has a discoloured brown disc ! Which lead me to believe that the caliper was at fault ! After jacking up the car and getting someone else to press the brakes there was little pressure goin to the pads ! The other side was rock solid so i replaced the caliper ! When out on road test there was still no braking on the o/sr caliper ! Now im stuck and dont know what to do ! The brakes were blead fine and rechecked after road test ! Can anyone shed any light onto my mysterious braking fault ????
Could be some other obstruction somewhere, a badly seized piston will stop the pads moving as well, but as you've done that with a known good one(?) this will be ok, so it's got to be fluid related.
Does it have abs, I assumed it would have, but if not check right from the master cylinder for pressure, will be easy to track down if no abs, I just take pipes off at brakes and blow compressed air down pipes, you'll know if one is blocked then!!
Life sucks.....Great dick
Hi,
have already seen more faults like this on RS2000 and S2 RST, most common fault are the compensation/biassing valves underneath the car. check them.
hope to be of any help
cheeRS
cheeRS
Hi mate , after pulling my hair out with it the other day i did notce that the compensator valve was abit clogged up so worked it free ! Ive not driven it since , as its only one of my toys ! lol ! After i did it though , i thought that if that was the cause the other side woudnt of worked either ! I maybe wrong though !
track.focus'd
12-08-2015 05:53 PM
