Pectel super 8...
Pectel super 8...
Allright guys,
Is anyone still running an old skool Pectel super 8 injector setup?.
I fitted the entire system onto my Vw 'raddo 16vt last year,no problems exept that the over-run fuel cut off don't work.
Why would this have been done/disabled?,i know this because the wide band drops to 0 when lifting off the accelerator pedel but only when using another
L8 ecu/chip,when i'm using the green lable cossy super 8 ecu the wide band stays rich,11 or 12 AFR on the wideband display so it's buggering up fuel consumption as the extra fuel ain't needed then.
Suggestions?
Thanks.
Suggestions?
Thanks.
Allright guys,
Suggestions?
Thanks.
Suggestions?
Thanks.
