cossie manifold
cossie manifold
What are the differences between a 2wd and 4wd inlet manifold. my 2wd cossie has a 4wd manifold on it that i want to get it powder coated but so the car isn't off the road a friend of mine has a spare 2wd which i can use is there that much difference or shall i take off my 4wd one.
cheers,
Phil
cheers,
Phil
the 4x4 one is only a 1 piece manifold and also flows air better,the 2wd manifold is 2 piece item but depending on your power the 2wd will be totally fine.
Just make sure you buy a 2wd gasket set.
07-10-2015 12:56 PM
caprixpack
25-09-2015 07:53 PM
