s1 over heating
s1 over heating
aaaaarrrrrr can any one help,my car warms up an i put the fans on at about 60,70
then it keeps rising ,,,,,,, it helps a bit if i put the heating on, im runing about 18,19 psi ,alloy rad from air tec big front mount twin fans right on the rad????????
dose any one now how good these rads are ???
thanks
Airtec are very good, certainly the best vfm as well.
Is it overheating ?, what happens if you don't put the fans on, what temp thermostat you got in there ?, why are you putting the fans on before it's up to operating temperature ?
Over heating
It's got no thermosat in it. If don't put the fans on early it will just rise an rise with the fans an heating on it will sit just under 100
it's so hot that when you open the bonnet you can't even touch the bonnet stands lol
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
cossie09
10-09-2015 06:56 PM
