Cosworth no spark
Old 24-06-2009, 05:46 PM
2ndGear
2ndGear's Avatar
Default Cosworth no spark
4x4 cosworth recently had an overhaul been put back together and no spark. Is there a way of testing the crank sensor and what reading should i be getting on the meter?
Old 24-06-2009, 06:23 PM
jon@work
jon@work's Avatar
Check resistance between hairbrush pins 3 and 4 between 300 and 1200 ohms.
Check AC voltage on hairbrush pins 3 and 4 while cranking engine - should be at least 2V.
Old 25-06-2009, 10:30 AM
GLSMAR
GLSMAR's Avatar
although I'm now running wasted spark - I had none until I plugged the phase sensor back in - might be an idea to check this - I believe it can connect both ways so it might be plugged in wrong.
JK12
33
26-04-2021 12:09 PM
tonicosworth
Ford Escort RS Cosworth
31-10-2015 08:40 AM
14-08-2015 07:29 AM
adriansaleem
01-08-2015 09:28 PM
Quick Reply: Cosworth no spark
