Cosworth 4x4 stg1
Cosworth 4x4 stg1
hi can any 1 tell me if i can i run a 3bar map sensor on a stg1 kit and run about 1.3 bar boost i got a G reg 4x4 cosworth scorpion zorst T3 TURBO -31 GGR chip grp a gasket currently running 1 bar
IVE GOT THE COMPLETE STG3 SETUP PTS CHIP 803 DARK GREENS AND THE 3 BAR MAP SENSOR PROBLEM IS THE LAST TIME I HAD THEM IN I MELTED A PISTON RUNNING 1.5 BAR FLAT OUT IN 5TH WAS VERY VERY NICE THOUGH
SO HOW CAN ONE SETUP A STG3 CHIPPED COSSIE IF YOU IN SA
DOES SETTING THE CO's on the ECU MAKE IT RIGHT WHAT % SHOULD IT BE AT IDLE AND THROUGH THE REV RANGE..
THANKS ALL
THANKS ALL
Anutternutter
21-08-2015 06:07 PM
charliecosworth
19-08-2015 02:00 PM
