oil light comes on wen car idles and flickers any one have any ideas ?
YES I KNOW I CANT SPELL
If the engine has a bit of wear, well a lot actually and it only does it at idle, so long as you keep oil changed etc I wouldn't worry, I've had cars with gauges where they went to zero at idle!!
So long as it's ok when revved is more important, if it does have crank wear this could o it, or even a low idle speed ?, others things as said also can cause this.
it idle just under 1ooo rpm but goes down and up iv just swapped the engines over and wasnt doin it wen i first started it it is s2 rs turbo im running it on 0w 4o motor sport have not been gettin much boost so i made the rod a bit shorter on the waste gate cheeRS for lookin people hope u can heellpp
It wont be the fact that its too thin to read the oil pressure - the fact is he has got low oil pressure probably due to the fact that the oil is too thin when hot - thus not being able to build up the correct oil pressure!!
